| yes you can recirculate a BOV, just makes no sense unless its an adjustable BOV and you are running higher then stock boost. but then youd want need bigger turbos and larger injectors and a chipped ecu anyways. so unless your going big just stick with the stockers. or unless you dont have/ cant find stockers. but yes you can recirculate aftermarket bov's no issues, so long as they are set to the correct spring tension for your setup. other wise they stay closed under idle so theres no reasson you it would idle funny.
